Climbed a snowbank. Guess I need a lift kit!
#21
Sagging has nothing to do with stuffing your rear tire up into the fender. You're stuffed because your leveling kit didn't contain the rear bumpstops like most 2.5" kits do. If you're rubbing then add bumpstops, otherwise disco and flex out to see what you really need...
#25
2 + 2 = bumpstops are the limiting factors for up travel (or shocks in a poorly setup system), NOT the coils! You will rub with 6" lift coils without proper bumpstops.
#29
