check out my project
Good luck with the build. I know many people are down on the turbo for the Jeep, but It should be a good project for you. Please post up the details and photos as you go. No matter how it turns out, should be interesting.
thanks guys for support and its going to be rear mounted in a cut out im going to weld up where the trunk is so its gona cut down on trunk space but i dnt care and its going to be done in january but ill be gettin it ready till then so ill post pics as i get parts and talk to the tuner
1 Post
http://www.ls1tech.com/forums/forced-induction/930244-sts-oil-restrictor-pump-install-how-fix-oil-intake-exhaust-pipes.html
If you get the right size turbo in there turbo lag pretty well won't exist. Most would consider a compression ratio of 9.6:1 a little high for a turbo, but it seriously decreases spool time. Tons of people told me I'd blow my engine when I put twins on my car ( which is 10:1 compression ) 7 years later and my only problem is traction.
Sponsoring Manufacturer
CAR being the operative word here; but why is putting a hot thing under our mostly plastic Jeeps, lowering the water threshold and risking pulling a low lying oil feed and/or return line off while crossing over soft brush - "better" - than a high mounted, self contained - proven product...(Filtering this through - you get what you pay for) - besides the price?
What are you going to use for engine management and fuel enrichment?
RIPPTECH
