Changes for 09 Models -Pix
#53
Re: Changes for 09 Models - Pix
You could always come over and see them in person I'm just down the road from you!
Center Stack Cargo Net:
Center Stack Cargo Net installed:
Console Tray:
Console Tray in place:
#54
Something is up with this one. My 09 ones are the same as my 07 was. Every one on the lot is the old ones also. However, if you look in the 2009 catalog it shows a new visor that is similar to the ones every other previous Wrangler has with the bent end near the roll bar.
#55
Thanks!!
#56
After one hour of trying to get the center console tray to fit in my 07 Rubicon, I gave up. I'm not sure, but I think they may have changed the center console sometime between 2007 and 2009! I will try to get to the dealer soon to attempt to confirm if there was a change in the center console.
Haven't tried to install the cargo net so not sure if that will even fit!
Will post back after checking!
#57
WARNING UPDATE!!!!!!
The center console tray does NOT fit in my 07 Rubicon (and probably any other 07 or 08 model ). I placed a call to my friendly local dealership (yes there are some of those types still around!!!) and asked one of the salesmen to check the inside of an 09 sitting on the dealership floor. He was able to verify there are some notches on the inside of the console that allow the tray to fit and prevent it from falling down into the lower areas of the console!
My next step is to go to the dealership - probably this weekend - and take a picture or two of the inside of the console to see if I can make some sort of support for the tray.
More to follow!!!!
More to follow!!!!
#58
More to follow!!!!
More to follow!!!!
#59
More to follow!!!!
More to follow!!!!
