The CFO Built By Rebel Off Road
Former Vendor
Use the following link to view all the images taken of our recent build.
https://www.facebook.com/rebeloffroa...70751752957939
2014 Jeep Wrangler JKU
Dynatrac XD60 Front JK Housing
- ARB air locker
-5:38 gear ratio
-stubby hub conversion
-crossover steering
-8x6.5
Dynatrac Prorock 80 rear JK housing
-ARB air locker
-5:38 gear ratio
-8x6.5
-1/4" wall tubing
Rebel Off Road exclusive TeraFlex Suspensions long arm upgrade for Recon Coilover Conversion
Includes:
- 8 arm upgrade
- drag link flip kit
- front track bar
- rear brack bar
- weld on long arm brackets
- brake lines
Rebel Off Road - complete Jeep JK Coilover Conversion System
Kit includes:
Rebel Off Road - front Coilover Conversion System (bolt on)
- front upper and lower coilover mounting brackets
- (2x) King Off-Road Racing Shocks coilovers 2.0 12" stroke with proprietary valving and spring rates
- grade 8 hardware
Rebel Off Road - rear Coilover Conversion System (bolt on)
- rear upper and lower coilover mounting brackets
- (2x) King coilovers 2.0 12" stroke with proprietary valving and spring rates
- grade 8 hardware
Rebel Off Road - front hydraulic bump stop Conversion System (bolt on)
- front upper recon bump stop brackets
- (2x) King 2.0 bump stops (Recon edition)
- grade 8 hardware
Currie Enterprises Anti Rock front sway bar
Fox ATS 1 5/8 steering stabilizer
Method Race Wheels 105 beadlock
40x13.50 r17 Toyo Tires Open Country M/T
J. E. Reel Driveline Services 1350 driveshaft
JE Reel 1410 driveshaft
ARB 4x4 Accessories dual air compressor
ARB air locker manifold kit
Daystar Products International JK lower switch panel
WARN Zeon 10-S
Winch fairlead mount
Poison Spyder Customs front and rear aluminum fenders
JK Brawler lite front bumper- trail stinger - tube gussets with shackle tabs
JK Brawler lite front skid
JK Rockbrawler ii rear bumper with tire carrier
Rock Slide Engineering Side steps 4 door with body armor
JK rear license plate delete cover
LED license plate and 3rd brake light
2 1/2 led back up lights
3/4 side markers amber
Borla Climber exhaust system
For a quote on your Jeep JK call or email us at 866-900-8841 / info@rebeloffroad.com
Rebel Off Road
www.facebook.com/rebeloffroadllc
www.instagram.com/rebeloffroad
