can you do this?
can you do this?
Evo front coilover system but not the rear coilovers so instead do like a terflax 3 in. Or teraflex 4 in. Kit in the rear? And then 37 in. Tall tires. And if possible what would it take to make this happen?
FWIW, that's the setup I'm currently running...EVO 12" coilovers in the front and a 3.5" spring setup in the rear. I'm pretty happy with it so far, but will still complete the rear EVOLever when the wallet allows
I have the 12" coils and FT 4" in the rear. Will be swapping to the OEM replacement Kings next week for the rear. Once money is there, I will do the evolever in the back.
Breakdown:
Front coilover kit $1600 - 1800
Rear springs and king shocks $1000
Long arm upgrade kit from Full Traction $1800
Adjustable trackbars front and rear $300
Adjustable Sway Links $300
Longer brake lines $100
Je Reel Driveshafts front and back $1000
Teraflex Speed Bumps $800
JKS Extended Front Bump pads $100
The feeling that you get when you hit speedbumps at 60 mph and float down the freeway: PRICELESS!!
I don't know about the labor since I did it, but you need to know how to weld and have patience and time to do it yourself.
Breakdown:
https://www.jk-forum.com/forums/arch...p/t-55321.html
My suggestion would be to call Off Road Evolution and talk to Mel. He'll tell you the minimum requirements to run the setup you are looking to do and like I stated we are running it and I'm sure a lot of other will be as well in the coming months. Good luck!
