Busy Beaver
Busy Beaver
Well, i was a little board last night and didn't have anything planned for today, so here is What I've been up to: Sanded and bedlined the hinges, installed a new parking brake handle, and am in the process of installing a 1-1/4 Rough Country body lift. Pictures will follow when I am done.
If you install the 1-1/4 Rough Country body lift, even if you trim the maximum of inner boot, during the cold weather, the inner/outer boot gets hard and it will pop up to neutral sometime. I tried it, and I removed it for a 1" body lift: just perfect
Read my write-up, you will see how much I trimmed the inner boot, and it's still not working at 100% in very cold temp.
https://www.jk-forum.com/forums/jk-write-ups-39/cutting-inner-boot-1-25-b-l-105452/
BTW, I like the black hinges. I have the same color, and I'll do it next Spring
Optus, I used dupli color bed liner bought at Wal-Mart. Wmcvey, I don't only have a bl, I also have a 3" Black Diamond Suspension lift. All of which I installed on the floor of the Garage Mahal. I am running 35x12.50 R17 BFG KM/2's with Terraflex wheel spacers.
