Building My Own Bumper 4/20/2010 SoCal Build: The Beginning
So this is going to be my first major fabrication project. Ive been talking about doing it for some time now and I have finally saved up a little money to get the ball rolling. Here is what I have planned so far but I wanted to keep in check with you guys as I go so you can correct me if I start to make a wrong turn before it actually costs me something, I know there are some experienced builders here that'll be able to help significantly. It is going to be a full rear bumper with swing away tire carrier, jerry can holders, hi-lift mount, and possibly a cargo cage on top.
So, first of, my plan, again please correct me or feel free to throw some advice in.
Step 1, starts tomorrow: The Mockup
I plan to do a cardboard cutout of the entire thing so that I can not only make sure I like how it looks, but then also use the cardboard pieces as stencils to trace on the steel when I am prepping for cutting. I plan to use 3/16" steel as this seems to be what most aftermarket bumpers are made out of. The bumper is going to mount straight to the to rear frame mounts just like the stock bumper does.
I want to use a similar hinge to the one that LoD uses for their bumper, can someone please dirrect me to a place I can buy just the hinge for the swing away tire carrier? Also if anyone has experience putting one of these on, any advice would be greatly appreciated, I want to make ure it is level, sturdy, and quiet.
I will continue this later when I get back from class but please start chiming in with advice, Im very excited to get the ball rolling tomorrow
PART 1 DONE!
The stock-ish start
Decided to use 3/16 particle board for the mockup/stencils, I started with the corners
The first fit of one of the corners
With the center portion
Getting close, just need the bottom angles
Mockup done
All done, I made it with many angles, high clearance corners but still full width, and, it works with the stock trailer hitch so itll be all tow rated and covered by the factory
Ill be getting the 3/16" steel to start cutting out soon, just gotta get a few other things done first. Hope you enjoy the progress pics, sorrry to leave you all hanging so long
Not much of an advance, but its something. The first steel parts
The main support brackets with support holes drilled, thats just a tiny bolt holding it up for no, bigger ones come later
Made them out of 1/4" steel
Both of them on
Took off the old supports and put the bolts back in the holes
More to come later
Update:
Been busy so havent had a lot of time to work but heres an update
Got the first corner tacked and welded, just gotta grind and clean up the outside welds. Im pretty happy so far
I will be starting the next corner either late tomorrow night or tuesday
PART 1 DONE!
The stock-ish start
Mockup done
Both of them on
More to come later
Update:
Use 3/16" fiberboard instead of cardboard, it is more sturdy. I used masking tape to hold the pieces together. You will have to use a saw to cut the fiberboard though. Great idea. I believe you can get a hinge from a-z fabrication.
Awesome, thanks for the heads up, and ill definitely check out a-z fabrication.
Another question I have is about the "one-swing" motion of opening it like expedition one's. Other than it just being less of a hassle to get into the back, are there any benefits to using this setup? If it is for support purposes I can come up with something but if it is just for access ill probably save myself the extra work for now.
Again thanks for the help guys, progress pics to follow
Here is my bumper build
https://www.jk-forum.com/forums/show...de-rear-bumper
The Swing out carrier that works with the stock gate adds a lot of work. I spent a lot of time trying to get all of the rattles out but it was worth the effort.
I no longer use a rubber hose on my support pin, now I use a nylon block. Also added a Polyurathane bumper on the top of the carrier to help. I found that the heims make noise unless they are always under tension, the poly bumper provides this.
Here is my support pin. I have zero weight on the gate due to this design.
Here is the gate fully closed. Note the black poly bump stop contacting the SS plate on the gate. This keeps the Heims under tension.
half way open
All the way open
One more picture
I also used the AtoZ bearing/spindle for my hinge.
half way open
All the way open
One more picture
There is another rear bumper build thread in here.....check that one out for info
https://www.jk-forum.com/forums/show...=1#post1637054
I bought the heavy duty version from AtoZ. One problem I had with it.... after welding my 2x3 tube to the spindle the heat egg shaped the tube slightly. This made the Bearing races imposible to install. Ended up spending about 4 hours Die grinder with sanding drums making the tube round again. The AtoZ site only shows this spindle being used with 2x2 tube, this would keep the heat away from the thin ends. Maybe Tig welding would work better, anyhow the moral of the story is to be careful with the heat.
If I was doing this again I would take a closer look at 4x4 labs spindle (I will send PM with link)
It is a lot thicker then the AtoZ spindle, and from what I can tell, is a stronger setup.
As far as installin the AtoZ, I just drilled a 1.5" hole in both the top and bottom of my 2x5 rectangle tube then welded both the top and botom of the tube. The bearings are setup just like a front spindle on a old 2wd car.
I assume you realize that LOD , Shrockworks and many others use a solid steel shaft on the bumper and the carrier contains the tube/bushing without the use of ball or roller bearings. Don't know of anyone who sells this style spindle for the "Homemade" market. The shaft that these companys use is very thick, most are 1.5" I think.
The Ato Z might be 1.5", but the bearing shaft is only 1"
Good luck
Thanks for the compliment.
Good luck
Good luck
As for progress, the whole thing is drawn up, just have to cut it out to make the mock bumper. Time has been very tight lately Pictures soon I promise, hopefully this weekend will give me a chance to go to town on this baby
my brother inlaw and I are working on two bumpers - one for the JK and one for his Dodge 3500 using the same idea as far as fiber board as a prototype. The steel yard in our area as a CNC plasma cutter that only cost $4 a minute for them to cut. It is fast and precise. You may see if any one has a service like this in your area...check it out...
santaritasteel.com/services.html
Last edited by sm_rubi; 05-04-2010 at 12:15 PM. Reason: Please refrain from posting direct links to companies who are not sponsors of Project-JK.com
