Build Thread: 2013 - JKUR - Slimer - SLC
It's hard to see but the extension is bolted to the hitch receiver. I welded a 13/16 nut on the inside of the extension (one side only, preferably passenger side for easier access). Next, screw a 9/16x1.75" bolt (with washer & lock washer) through the stock receiver into the extension to the welded nut. I used this size because it was the biggest I could get through the hole. It'll tighten up to where you'll have no movement in the extension at all. Also I noticed your extension is huge, you can find them as small as 4" (recommended), it'll push the rack out just enough to clear your spare tire.
Note: this extension modification should NEVER be used for towing and ONLY be used for you bike rack.
TeraFlex 4" Long Arm Suspension System
TeraFlex Speed Bumps
TeraFlex Sleeve and Gusset
TeraFlex Front and Rear Differential Covers
TeraFlex Hinged Tire Carrier
37” BF Goodie KM2 Tires
17” Ballistic Jester Wheels
Fox Shocks
Fox Front Stealing Stabilizer Shock
5.13 Gearing - Front and Rear
Ball Joint Swap
Wheel Spacers
Locking Lug Nuts
Before
After (Warning: Poser Shot)
Fox Shocks
Ball Joint Swap
Wheel Spacers
Locking Lug Nuts
Before
4" TeraFlex Longarm
Fox Shocks
Ball Joint Swap
Wheel Spacers
Locking Lug Nuts
Before
Attachment 505755
After
Attachment 505756
Fox Shocks
Ball Joint Swap
Wheel Spacers
Locking Lug Nuts
Before
Attachment 505755
After
Attachment 505756
This will do the trick and for cheap - Amazon.com: StowAway Hitch Tightener: Automotive I have two - one for the extender and one for the bike rack. You may need one or two depending on how well the bike rack fits into the receiver/extender. We have a Soft Ride bike rack and it may be more or less snug than yours.
Thanks! I'll look into that.
Here some pics of the GF and I putting on the TF tire carrier.
Attachment 505890
Attachment 505896
Attachment 505897
Attachment 505890
Attachment 505896
Attachment 505897
