Build Thread: 2013 - JKUR - Slimer - SLC
Old 10-07-2013, 09:50 PM
Darmada's Avatar
Originally Posted by jolson05
There is still a lil' vertical wobble in the hitch extension. Anyone got any ideas on how to tighten that up?
what i did with my yakima rack is i used some duck tape and wrapped the hitch a couple times and it solved the wobble...not the best thing but it worked
Old 10-08-2013, 03:38 AM
Tripletsi's Avatar
Here is the perfect fix (you had the right idea in the 5th picture!):
It's hard to see but the extension is bolted to the hitch receiver. I welded a 13/16 nut on the inside of the extension (one side only, preferably passenger side for easier access). Next, screw a 9/16x1.75" bolt (with washer & lock washer) through the stock receiver into the extension to the welded nut. I used this size because it was the biggest I could get through the hole. It'll tighten up to where you'll have no movement in the extension at all. Also I noticed your extension is huge, you can find them as small as 4" (recommended), it'll push the rack out just enough to clear your spare tire.
Note: this extension modification should NEVER be used for towing and ONLY be used for you bike rack.
Old 10-17-2013, 09:08 AM
jolson05's Avatar
TeraFlex 4" Long Arm Suspension System
TeraFlex Speed Bumps
TeraFlex Sleeve and Gusset
TeraFlex Front and Rear Differential Covers
TeraFlex Hinged Tire Carrier
37” BF Goodie KM2 Tires
17” Ballistic Jester Wheels
Fox Shocks
Fox Front Stealing Stabilizer Shock
5.13 Gearing - Front and Rear
Ball Joint Swap
Wheel Spacers
Locking Lug Nuts
Before
After (Warning: Poser Shot)
Old 10-17-2013, 10:05 AM
brikino's Avatar
This will do the trick and for cheap - Amazon.com: StowAway Hitch Tightener: Automotive I have two - one for the extender and one for the bike rack. You may need one or two depending on how well the bike rack fits into the receiver/extender. We have a Soft Ride bike rack and it may be more or less snug than yours.
Old 10-17-2013, 01:32 PM
nvglockster's Avatar
4" TeraFlex Longarm
Fox Shocks
Ball Joint Swap
Wheel Spacers
Locking Lug Nuts
Before
Attachment 505755
After
Attachment 505756
That is taking shape nicely!
Old 10-17-2013, 02:56 PM
jolson05's Avatar
Thanks! I'll look into that.
Old 10-17-2013, 03:02 PM
jolson05's Avatar
Pics of build...
Old 10-17-2013, 07:34 PM
jolson05's Avatar
More pics of the build...
Old 10-17-2013, 07:39 PM
jolson05's Avatar
Here some pics of the GF and I putting on the TF tire carrier.
Old 10-18-2013, 12:05 PM
brikino's Avatar
Attachment 505890
Attachment 505896
Attachment 505897
Did you mean to say, "Here's a photo of my girlfriend putting the carrier and tire on while I'm sitting back drinking a beer, taking the photo and watching her do all the work"? Well played sir.
Quick Reply: Build Thread: 2013 - JKUR - Slimer - SLC
