BRUT4CE goes 4dr build
#21
Made some mounts for dual duallys....1 spot on Top 1 flood next to it......
Figured since I dont do night runs alot and don't want a massive light bar this was good...ran 1 dually spot per side on my last one and worked out GREAT.... We do a lot of camping with the kids so this works out more than needed....
#23
#24
Former Member
1 Post
Started my front bumper, it will have a winch fairlead mounted to the front as well as d-rings sticking through the front plate. Deciding on a stinger or leave it...
I copied the lower design of my PS bfh for simplicity but changed a couple items more...
Started my CJ grill cut as well...chopped 3"+ off the front of the frame to accommodate a better approach angle.
Bumper has 3 gussetts in the lower section and is solid ready for the rocks....It will be dialed when I get the winch to fill it in the light bar and do a couple more custom goodies to it....
And of course you can see the grill chopped here I need to do some finish work and some flush mount led turn signals...
#29
Former Member
1 Post
Finished my cj grill cut
Did front led turn signals
Dd flush mount rear led lights (waiting on reverse lights to co e in)
Wired up the rigid dually's on pillar
Relocated evap canister
