BRUT4CE goes 4dr build
Former Member
1 Post
BRUT4CE Rubicon 4dr build
Sold the 2 Dr and grabbed a 2010 Rubicon 4dr fully loaded TVs in headrests for the kids, GPS, ICO next, nav, voice, leather etc....top has never been off 1 owner all receipts of maintenance and never OFF roaded, still under warranty.......has some 20s with 35s lol so now it has some race line be ad locks going on with 37s or 40s....
Started chopping the rear frame flipped the cross member reinforced the hitch remounted the body mounts between shocks and new cross member location....cut the front bumper....chopped off the exhaust did a magnaflow that dumps before the axle, relocated the evap canister....
Got some race line beadlocks and deciding between 37s and 40s.....
Did a dynatrac front diff cover....
So this weeks to do list is side armor rear corner armor, a tire carrier that swings out of the back with full storage under it, back door is getting removed, windjammer and bikini top will be the typical setup...
This build will be a while but will be a big brother to my red one.....all shock mounts are getting chopped relocated all arm pockets chopped and heavy duty ones welded on....synergy 4" springs and so on.....should be extremely capable and will be built solid....eventually d60/14 bolt swap.-..
Update what's been done as of 1/16/2014
Modified rear frame made bumper
Modified front frame made bumper
Chopped lower control arm poc,dhs made new raised units with shock tabs
Made new raised and rotated wonder front shock tabs
Synergy sleeves
Synergy c-gussets
Artec front truss
Artec rear truss
Race line bead locks
37" toyos
Rock light kit
Hid headlight conversion
Led interior lights
Custom rear ligjt plates with leds
Rear tkre mount
Rear basket
Rear wall
Fox 2.0 resi shocks
Synergy ball joints
Rewired factory lockers
Custom dual dually windshield mount
Warn xd9000i with synthetic line
Custom tune fenders
Rock sliders
Rear side tub armor
Tapped steering box for hydro assist
Cj grill chop
Ten factory chromoly axles
Custom axe mount
Side bar for rear reservoirs on shocks
Spring retainers
Co2 tank 20lb
Rear dust lights
Synergy sleeves
Synergy c-gussets
Artec front truss
Artec rear truss
37" toyos
Rock light kit
Led interior lights
Rear tkre mount
Rear basket
Rear wall
Fox 2.0 resi shocks
Synergy ball joints
Custom tune fenders
Rock sliders
Rear side tub armor
Cj grill chop
Custom axe mount
Spring retainers
Co2 tank 20lb
Rear dust lights
Former Member
1 Post
So will I....lol
Just did a full poly weld in cage in it , rhyno lined it, harness, metal front fenders and new gusseted diff covers for the new owner...
he bought it had it home for 2 days then it was back with me for 5 getting built more...now its back in his possession.
I will say a 2 dlor built is more capable in the rocks then a 4dr...I hit the same nasty team.s and the 2 dr walked through the rocks easily...
So will I....lol
