Brakes not working
Just curious, did you start it up and push the brakes a few times between brake bleeding? That will turn the ABS on, and should let them run and get any air that they might have out.
And were you uding a brake bleeding tool, or were you doing the old 'open valve, push the pedal down, hold, close valve, lift, rinse, repeat" method?
BTW: Worthless, Dana corp doesnt make the brakes. For many years (like 40), they were GM brakes. Now they are chrysler brakes. But dana didn't design them.
Yes I am aware of this, Dana was stated to reference that particular type of axle. I work on lots or Toyota, Suzuki and Rockwell axles and wanted to be clear as I have never had issues with those brakes.
