Black Key Hole
Old 08-06-2012, 04:42 PM
  #21
VolsJeep's Avatar
Originally Posted by Og57
Looks great, wouldn't have thought of the hinges but I like them. I just painted my antenna with plasti dip, luv the stuff!
Did it affect the signal?
Old 08-06-2012, 05:08 PM
  #22
Hskr4x4's Avatar
I haven't put keys in them because I have keyless entry BUT I can tell you the bedliner is TONS more durable than paint and plastidip
Old 08-06-2012, 05:30 PM
  #23
VolsJeep's Avatar
True, and that's what makes me want to use bedliner. But I don't have keyless entry, so I have to go old school. My concern is that a layer of bedliner will restrict the key and possibly cause the key not to work.
Old 08-06-2012, 06:50 PM
  #24
HogHoden's Avatar
Originally Posted by VolsJeep
If you're going to straight out paint it, would you recommend sanding it?
I didn't sand it at all. I just cleaned the surface and then taped off around it. The high heat flat black paint stuck just fine and held up to pressure washing for years.
Old 08-07-2012, 04:32 AM
  #25
Og57's Avatar
Doesn't seem to, I use mostly the Sirius, but am fm seem to be same as always.
Old 08-07-2012, 05:23 AM
  #26
TrainReck's Avatar
Originally Posted by mrEman81
I plasti dipped mine along with the hinges. It really looks a lot better and breaks up the color a bit more.
This looks really good
Old 08-07-2012, 08:40 AM
  #27
1978cj7jk2012's Avatar
Plasti dip works good just he easy on it.
Old 08-07-2012, 08:48 AM
  #28
scott franklin's Avatar
Those look really good. I'm gonna have to try that on mine!
Old 08-07-2012, 09:32 AM
  #29
Vin
Vin's Avatar
I had half a can of black paint and was bored one day. I taped off my locks and trail rated badges. They are still holding up.
Old 08-11-2012, 11:53 AM
  #30
VolsJeep's Avatar
Well, I did it. I bought Plasti Dip and painted the key holes. I also painted the taillights, antenna, and trail rated badge.
ID:	352884   Click image for larger version
ID:	352886   Click image for larger version
ID:	352887   Click image for larger version
ID:	352888   Click image for larger version
ID:	352890   Click image for larger version
ID:	352891   Click image for larger version
Quick Reply: Black Key Hole
