Bestop Soft Doors Installed
Got my 4 soft doors (uppers and lowers) this week and put them on, they were very easy to adjust, I have seen some posts of people saying they took them hours, I just hung them up with all adjustments loose, latched the door and then reached in and tightened them all, they all swing and align perfect 5-10 min a door for setup! My over all thought of them is they are great, fit the jams good are very light and is perfect for the good weather coming upon us, at highway speeds the tops dont start to pull out away from the jam until i hit around 68-70mph and after that its like maybe a 1/2" I dont speed around much over 65 anyways so all is well with that, they are not that loud, they do have a slight flap here and there but not bad at all, I am very happy with them and glad I bought them.
Just figured I would share my findings for anyone that is looking to pull the trigger on a set, but not sure due to mixed posts on them. Im glad I did.
they are cj driver side brackets (cj driver side works on both sides of the jk!) with 5 inch round mirrors bolted on them.. the bolt holes line right up if you caddy corner the bolts through the bracket...
