Benchmark Designs Elite Rear Winch Bumper/Tire Carrier
#71
#72
Hmmm...how do you make the adjustments Rafi? Is it with the bumpstop that you had to move? If so, what is the bumpstop made from? Do you think it will settle or squish a bit after having the carrier against it for a while or is it pretty rigid? I'm just wandering if you should set it tight and see if it flattens out and loosens up after a day of pressure. (hopefully not so much so that it begins to rattle)
#73
#75
Originally Posted by Rafi
You guys think it's alright to drive around with the weight of the wheel on those long studs?
