Belly Up
#21
2climb, you ever do this? i know your working on your rig now and this is the part im at. I can get about 3/4" higher before it hits the heat shield. Id say a body lift is a must, but then like you said i believe the motor mounts and such may need to be adjusted as thats a big difference in angles. I see genright has a kit they claim is a belly up and only requires there crossmember, but i see no way. I will probably end up just raising my crossmember 3/4"
