Before/After
#26
Very interesting update on tire rub!
Discovered the rubbing noise the tires are hitting the air dam but found something else that was disturbing but I hope I know the answer to but Im looking for input . Went to a flat parking lot and kept doing slow tighter circles until I heard the rubbing, stopped got out and saw the tire against the air dam no biggie, but when I ran my fingers around the back of the opposite tire to check clearance I could not get my fingers between the tire and the frame on left side with wheel turned to the left! Im not even sure I had it at full lock yet, hoping this relationship will change with a lift and/or adjusting the limit of the stops?
Adjusted the psi to 30 from 35 seemed to make a difference less side to side movement thru the body or im just getting use to it.
Let me know whay you think!
