Back In Black ( Before / After Pics )
The backspacing is 4" and the tires are 35's. I did not test fit all five wheels before I mounted then, just one. I just went right to grinding to make sure that they would all fit. I would then not have to worry about rotating tires or using the spare.
Im looking at trading up as well... I have a white TJ, not a Rubi, but I've put a lot into it...
How did you do the swap? Did you trade in or did you sell it? Probably sold it... with all the work it looks like you put into the TJ, I doubt you'd let yourself be bent over on a trade-in? Maybe not?
If so, did you part it out prior to selling?
I sold the TJ on Ebay. The only item I sold separate was a set of trail ready beadlocks with BFG Krawlers mounted that were used for offroading. It only had 9000 miles on it and was not a daily driver. This rubicon has to make the commute everyday and will not be as built as the TJ.
