Back in Blac ... painted my Eagle Alloys ....
Old 08-29-2010, 01:25 PM
jesse0376's Avatar
Default looks good
im usually not a fan of black wheels but i think they look really good on your jeep! good choice!
Old 08-29-2010, 01:26 PM
ksk
ksk's Avatar
Lookin good...lookin good
KSK
Old 08-29-2010, 01:33 PM
dxfiles's Avatar
HI--looks good---get some black lug nuts---pull the centers and paint your hubs---did that yesterday...take a look--Joe
ID:	84540   Click image for larger version
ID:	84541   Click image for larger version
Old 08-29-2010, 02:07 PM
dmhines's Avatar
Originally Posted by ISSY
Looks great! You should go with black lettering as well.
Did you paint those with the tires on? I want to do this with the stock rims that came on my Sahara.
Yes ... I plan on going with matte black lettering .... i used the playing card trick and painted them with the tires mounted. Just get a few packs of playing cards. Insert them all around in between the wheel and tire .. perfect mask. I did all 5 wheels in less than 2 hours ...
Old 08-29-2010, 02:08 PM
dmhines's Avatar
Thanks looks good .. I just bought these solid steel lugs nuts... the factory ones suck.
Old 08-29-2010, 04:08 PM
Bacon's Avatar
that's awful quick. did you scuff the surface of the wheels first?
Old 08-29-2010, 04:24 PM
dmhines's Avatar
Yup .. bought a couple of those foam sanding blocks from Walmart when I picked up the Bed liner ...
I jacked up a corner and removed wheel and tire.
I cleaned the wheels with simple green and then wax and grease remover.
Then I scuffed front and back with sanding block.
I inserted cards to mask the back and applied two coats as per the instructions.
Flipped wheel around ... inserted playing cards and sprayed the front two coats. I put masking tape on the valve stem.
I let dry for like 5 minutes and then reinstalled on jeep so I could do the next corner. It was really no more than 20 or 25 minutes per wheel ... and I did the matching spare as well.
Old 08-30-2010, 06:53 PM
AK4Dave's Avatar
Originally Posted by BuckLisa
Black looks great! No chrome with black/blue
They weren't chrome, they were polished aluminum.
And to dmhines....I hope you have good luck with the paint sticking. Normally it takes a bit of prep, as in using some form of etching to keep paint sticking on aluminum. I haven't done it in so long, I don't know what they do now. I think I remember people using vinegar last to clean aluminum just before painting. Paint has changed a lot over the years tho, and you might get lucky and it will stick good for you. Hope so or you'll be looking at them being aluminum again. Then you can just sell them to me....lol
Old 08-30-2010, 07:09 PM
jonnybo20's Avatar
looks awesome ! i am really tempted to chop my fenders too but not sure how they would look with colour matched fenders all cut up ? and i think the wife might have a few word with me if it turned out really bad ! but other then that i really like your set up ! looks great with the half doors too !!!
I liked the look of my Soft 8's ... but got the better deal on the Eagle Alloy's and I sold the 8's... so I painted the Eagles this morning with Rustoleum Bed liner ... same stuff I use on my bumpers ...
Before:
After:
Quick Reply: Back in Blac ... painted my Eagle Alloys ....
