AtoZ Rocker guards Installed!
Finnally Have these bad boys on. Directions for these were ok but could have used some more steps.It is really easy and I found out after installing the first one to break off the two front welded on nuts that hold the front fender on. This gives you a hole instead of drilling a new one. The use of the floor jack is essential and a second hand doesnt hurt either...thanks honey(wifey) Finnished product this is a body and pinch seem mounted setup...but I jumped on it all 210lbs of me and it is totally solid. Hope this helps anyone interested in these. Took all of 2 hours to install.
Looks good from what I can tell (pics are a bit small)... If you get a chance to smash it on a few rocks let us know how it holds up. A lot of people are skeptical about pinch seem mounted rockers.
I have to thank Toad (one of the modrators on here). Hers look like they are holding up quite well. I beleive the stock Rubi ones mount in similar fashion(body mounted that is). I could be wrong. I am planning on a trip here real soon and hopefull I can get some pics posted up in action. Thanks for the compliments.
I also have the AtoZ rock rails and I really like them. I have dragged them across a few rocks and they seem to be pretty tough. It wasn't mentioned above, but they are mounted to both the pinch seam and the body mounts.
