Atlas 4-speed
No offense to Screamin (love you guys) or Northridge, but you may consider going straight to the source on this one. There are all kinds of details (flange, shift options, ratios, etc) that they will walk through with you. This is one of the more major mods you will do with your JK. Spend the time asking questions and finding out all you can before you dig into it. Then when you do, get the Superchips Flashpaq. The Crawler tuning is unbelievable with it!
Ok Thanks. I saw you choose for the 5.4 reduction why you did that, an not for the 3.8 with the 10,3 ?
When you replace your driveshafts did you also buy the flanges by Tom Woods ??
Thanks Marc.
Thanks Marc.
David
The flanges and such are part of the things you need to think about before ordering as Atlas installs them for you. I went with the forward high, rear low shift pattern so as to keep the levers away from my center console while wheeling. That makes it easier to reach my locker switches and such I've installed there. That's just some of the stuff you want to consider.
an atlas 4spd is a t-case for the jk. it replaces the stock one and has a dual shift pattern for low ratios and if equiped front digs. it is more for the hardcore crowd but the benifits and crawl ratios are endless. u can pretty much customize it to your liking as well. if i had the money (lik everyone on this forum most likly) i would have one already
