Atlas 4 speed
Okay, I finally got out from underneath the JK and got the chance to trail the full working version of the Atlas 4 speed transfer case. Whooo Hooo! Loved it! There is still much I have to learn about about it, but these are my thoughts as of now:
The 10:1 ratio version would be a waste of money. I have the 2.77, 5.44 ratios and they are outstanding for the mountains.
The two stick gives a great deal of maneuverability on switchbacks. You're still in low, but only engaging one of the axles cuts the turning radius way down.
The low planetary (5.44 side) is awesome for any descent. I have an auto so throwing it into first gear makes it so I actually have to give it gas to go down most obstacles. It was only the near vertical and wet faces that required any braking. Second and D kept me going slow down the rest. For up and level, a quick shift into the hi planetary(2.77) and I was keeping up with the rest of the group.
I had some skid plate and transmission issues, not to mention there was still way too much snow in the high country to do much more than winch a lot so I cut the trip short to come home and fix things. I'll keep you updated as I gain more experience with it.
Pretty damn awesome! Seer1's experience pretty much mirrors mine. Off road I like it better than the Hemi and maybe even my lockers. I just wish I had more time to use it. If I ever get the time, I'll even put a poor mans cutting brake in. But time is someting I just don't have.
So seer1, or anyone else who has the 4 speed, is it worth spending the extra for the ele. switch? its like what $450 extra? wont the lever work the same, just mod the center consol or make a bracket to mount it?
I finally set up my shifter so it only shifts when the engine's off. You can't do that with a manual so each have their advantages.
