ARB bumper and tow bar brackets
Once and a while I see people looking for info on tow bar brackets. Here is a picture of my 2012 JKU with a ARB front bumper and a tow bar system. So when you go around and people tell you there is no brackets available just be persistant.
For some reason I can't find my paperwork to give you the part # right now but I will add it later.
Did you have to relocate the pump to install the bumper? just got my 2012, and was wondering if I need a relocate kit..
My 07 also had the arb deluxe and the rv tow package... worked great.
If only there were a base plate that would work with the ARB deluxe bumper
Nice pictures…on several forums, but you never say what the make of the base plate is or what modifications you made to make it work. So sad.
DEMCO baseplate with ARB Deluxe bumper
I made it work. You can install a DEMCO baseplate under the ARB deluxe winch bumper. A small portion of the base plate end must be removed and a small portion of the thin metal inside the ARB bumper must be trimmed, but it will work. Longer bolts for the bumper are required.
