ARB Air Comp installed
1 Post
Thanks guys. The install in the jeep was easy. Getting the pump mounted to the bracket was the hardest part. I definitely recommend attaching the pump to the bracket out of the vehicle. Hopefully I will get the wires run here in the next day or two.
Install
Hi I'm going to do the same setup you have this Sat. But the wiring has me a little puzzeled and I have the SPOD-ARB pigtail also, no lockers yet but soon. Any tips beyond the put motor on bracket first? Thanks
Thanks again for the tip about attaching the pump to the bracket before installing the bracket. I fitted the bracket snug then adjusted all the variables on the pump,scratched marks where the pump fit, removed bracket,married the two and reinstalled the combined unit. Then the fun began a I encountered a phantom problem that wasn't what it appeared to be but thanks to a couple of guys on the forums got it solved quickly. Cheers,
