Anything AEV
#32
your disco's are upside down, if it matters. both grease fittings should be pointing forward.Attachment 366900
The reversed Zerk fittings are the result of shortening the links as much as possible, but now they are in I see it makes more sense to to point them the same way. Half a turn won't hurt the length.
#34
#37
Originally Posted by SKTN Rubi
Aev heat reduction hood with some contrast. Hoping to get aev front bumper by winter. Rear by next spring.
#38
#39
We can't say enough good things about the AEV lift install. Thank you Kent, Dave, and Jordan!
The progressive springs really improve the handling ... and off set additional weight from front end accessories (AEV front and Rock Hard rear bumpers).
Hard to believe that the around town ride is softer/ smoother and off road feels firmer.
They have engineered just the right spring rates coupled with the shock valving.
