Anything AEV
#171
The Jeep I helped my Uncle put together.. AEV bumpers front and rear. Local 4x4 shop made a custom bracket to install the solenoid for a the Warn M-8000S.
#172
Added the tire carrier, hilift holder and CHMSL. 2.5 XT lift and 35's on the stock rubi wheels is next in line.
Note: the CHMSL with the AEV supplied bracket does NOT fit with the new Rubicon wheel, the tab is too wide for the wheel hole, if it was 0.5" higher it would work. I fabbed a mount from some aluminum angle for it so that it would fit.
#173
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=488370"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=488371"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=488372"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=488373"/>
#174
#175
Filled my water tanks today and there was a slight drip on the driver side. Had to take the "pod" off and retape the threadsat the quick connect. Running "fully loaded" with liquids to test it out before hunting season.
If anything goes I want it to go when I'm not in the middle of nowhere.
