Anything AEV
Old 08-14-2013, 11:21 AM
  #171
sacdaddy03's Avatar
The Jeep I helped my Uncle put together.. AEV bumpers front and rear. Local 4x4 shop made a custom bracket to install the solenoid for a the Warn M-8000S.
Old 08-14-2013, 07:04 PM
  #172
Joe with the flow's Avatar
Added the tire carrier, hilift holder and CHMSL. 2.5 XT lift and 35's on the stock rubi wheels is next in line.
Note: the CHMSL with the AEV supplied bracket does NOT fit with the new Rubicon wheel, the tab is too wide for the wheel hole, if it was 0.5" higher it would work. I fabbed a mount from some aluminum angle for it so that it would fit.
Old 08-14-2013, 07:12 PM
  #173
evoviii2jk's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=488370"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=488371"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=488372"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=488373"/>
Wirh my fuel trophies I had to flip the bracket around so it sat inside the wheel
Old 08-14-2013, 07:30 PM
  #174
Doi. I don't know why that didn't even cross my mind at the time hah, that would probably work. Now I'm gonna go cry.
Old 08-14-2013, 07:32 PM
  #175
Schleprock's Avatar
Originally Posted by JKJody
I have not put fuel in it yet. And im nout running the hi lift mount or jack yet. I do have 35s soon to be 37s and there is a little resistance but im used to it. But ill let you know on the fuel when i put it in.
I filled mine last week and it seems to be about the same as far as the resistance goes....
Filled my water tanks today and there was a slight drip on the driver side. Had to take the "pod" off and retape the threadsat the quick connect. Running "fully loaded" with liquids to test it out before hunting season.
If anything goes I want it to go when I'm not in the middle of nowhere.
Old 08-14-2013, 07:34 PM
  #176
k0260's Avatar
Originally Posted by AmericanICON
Attachment 483287
AEV 4.5 and 37s with Bilsteins, heat reduction hood and Hemi kit
That rig's a real beauty
Old 08-14-2013, 07:51 PM
  #177
mattgt5's Avatar
That is a beast.
Old 08-16-2013, 05:15 AM
  #178
TyroneHightower's Avatar
Everything AEV except for the Clayton Off Road 4.5 inch lift. AEV roof rack will be installed next week.
ID:	488642Click image for larger version
ID:	488643Click image for larger version
ID:	488644Click image for larger version
Old 08-16-2013, 07:28 AM
  #179
Razorbak's Avatar
Finally got my first AEV Mod.
I will be looking to get the front bumper next year.
Old 08-16-2013, 08:56 AM
  #180
AmericanICON's Avatar
Thank you sir!
Quick Reply: Anything AEV
