Anyone plasti dip their hard top interior? post pics.
Does plastic dip if I'm dying it wright, does it have a smell like paint? My jk is black on black but the inside of my hard top is white and I want to paint it but I'm afraid of it smelling like paint for days are longer. We have very hot summers here to and being a dark color attracting the heat I also don't want to spray something that will get soft are tacky.
I painted the inside of my hard top with
duplicolor bed liner. Came out great and holds up much better than original paint. It did smell like paint for a little bit, but I did it in the summer and ran my soft top while it aired out. There are a couple threads about how to do it.
The fumes will destroy your lungs if you apply it in a closed space, but once it's completely dry I don't think you'll have residual smell. You might want to start with a single freedom panel first and see how it goes. One panel will actually be a bit of work to cover; I can't imagine trying to spray the rear interior (get one of those squeeze triggers or your index finger will fall off)
I did mine to see if I would like the black interior. It does wear off on the friction points but it isn't meant to be permanent so I expected that. I did let mine dry for a couple of days before I put it back on. I will post some pictures up for you tomorrow when I am at my computer.
I used Rustoleum Universal in Satin Black. It leaves just enough of a sheen for a smooth surface which makes cleaning them easier than a rougher surface like bedliner or flat black. I wouldn't recommend plastidip simply because its not permanent, but that's just me.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=424106"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=424105"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=424107"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=424108"/>
Attachment 424106
Attachment 424105
Attachment 424107
Attachment 424108
Attachment 424106
Attachment 424105
Attachment 424107
Attachment 424108
Wow you did an amazing job, I really like how its not crazy shinny. I was going to use plastic dip on the inside and Bedliner on the outside because inside plastic dip is crazy easy to fix if it chips or peals with a little thinner and a left over PD spray can. And if u wheel or take the tops off a lot, they chip and scratch toooooo easily. So the bedliner on the top. Logically speaking. LoL
This type of spray paint doesn't require it, it's similar to Krylon for plastic, just Rustoleum brand. If your top is in good shape, just get painting. Mine had 4+ years of crud buildup so I used a fine grit sanding sponge and a degreaser (like fantastic) to wipe it down really well before painting. It's up to you how much prep you want to do. I've seen pics of some guys who didn't even clean it & just start painting and they came out really well.
I want to plastic dip my interior but I want to see how other people done it before I start doing it tomorrow I'm so if you could post some pics that would be kind of awesome. I've seen 12 pics but no close ups on over hopefully it sound deadening and other plus he did it I did that anyone has. Please post your pics because you telling me doesn't help show me what it's going to look like. And personally annoying when people ask others to post pics of what they've done and all they do is tell you .
If anyone is going to plastidip the underside of their roof panels just know that it's really temporary. Even the process of taking the panels off and putting them back on your jeep will most likely take off some of the plastidip, whether it be the panel hitting the frame, or just unlatching the panels...
Other than that, it looks awesome! haha I'm probably going to take it off in a month and bedline the whole underside of the panels/rear cover. Here are a couple pictures:
