Anybody is using Daystar Stinger bump stops or the Teraflex Speedbump bump stops?
I am planning to install a set of Stinger bump stops from Daystar on my front coil springs, but I dont know what will they look like after the installation, so if anybody is using them or the ones from Teraflex, please post some pictures. Thanks!
Thanks for the reply! From the pictures, I can see there are still much spaces between the Teraflex bump stops and the bottom of the coil springs, however, what length of Teraflex bump stops are you using? Will the Stinger bump stops from Daystar exactly the same after the installation, or the bump stops be more longer so that they are "touching" the bottom and the top of the coil springs?
In fact, the Daystar is offering two length of the stinger bump stops, one is like 11.25" when extended,and the another one is like 8.25" when extended; I am going to post up some pictures of my jeep's coil springs, please tell me which one of the bump stops from Daystar should I use. Thanks!
