Another transfer case explosion/fire
Old 04-01-2011, 06:47 PM
  #21
u-joint's Avatar
Originally Posted by DTJK
Or Prorock Unlimited.
Really? I am ignorant... Do explain. Is it because the unlimited as the pinion angle adjusted? Couldn't you accomplish the same thing with adjustable control arms?
Old 04-01-2011, 06:50 PM
  #22
runit3's Avatar
I had just gotten the Jeep back from Northridge where prosteer ball joints had been installed and the entire front end was rebuilt due to a different shop royally f***ing up the front gear job. To my knowledge everything looked and felt in spec. The vibes only lasted about 40 miles before the damn thing exploded. REALLY bad for the last 4 miles but I had no where to get off the highway and I had slowed down considerably. Just as a warning if you feel driveshaft vibes to the point that it's felt in the steering wheel just get the hell off the road ASAP.
Old 04-01-2011, 07:00 PM
  #23
ronjenx's Avatar
The Prorock Unlimited has 10° of separation between the pinion axis and the king pin axis. The stock JK axle has only 6° of separation.
Old 04-01-2011, 07:07 PM
  #24
robsjeep9's Avatar
Originally Posted by ronjenx
This is the recipe for disaster:
Lifted
Regeared
After market front drive shaft with single joint at the pinion, double cardan at the t-case
An adapter at the t-case that increases the distance of the double cardan from the t-case.
Front pinion more than a few degrees out of alignment with the drive shaft
Highway speed
That's when you are tooling along, fat, dumb, and happy, (no offense, it's just an expression), then you suddenly hear the onset of vibration. Then, all of a sudden, KABOOM!
It's happened to quite a few JKers.
The thing that would prevent this is getting the front pinion and drive shaft into alignment. The double cardan at the t-case requires the front joint to be in alignment with the drive shaft.
But then, that cant be done on a lifted JK because you would have too little caster.
Thanks for the explaination ..... I'll have to check my JK out .... Teraflex 3" lift with 4 flex(control arms) new front track bar and stabilizer kit... Running on MT MTZ's 35". Hope I can sleep tonight...lol... Long day at work tomorrow. Rob
Old 04-01-2011, 07:18 PM
  #25
DCJEEP's Avatar
Stupid question will this happen using the stock shaft on a 4.5" lift?
Old 04-01-2011, 11:51 PM
  #26
runit3's Avatar
assuming your stock shaft hasn't torn a boot, or ran into the skid, it may survive.
ronjenx is right on with his explanation. I had all of the things mentioned in 16. I'm trying to rationalize what I'm going to do with the Jeep, I've had to drop what is going to total over $6000 in necessary parts due to breaks/wear and tear in the past 12 months...It's getting ridiculous. If I could do it all over again I would have bought a new rubi, stayed under a 4" lift and stuffed the tires. Going over 4" of lift on a 2dr with D44's is just pointless IMO.
Old 04-02-2011, 01:20 AM
  #27
shockwaveaz's Avatar
Would a double cardan at both ends of the shaft prevent this? I'm willing to change my setup to prevent this.
Thanks
Sent from my PC36100 using Tapatalk
Old 04-02-2011, 07:19 AM
  #28
ronjenx's Avatar
Thanks
I don't think so. Just picturing it in my mind, it looks like the drive shaft would flop around.
Old 04-02-2011, 08:09 AM
  #29
Lol ok I, just saws it as an option on Tom Woods. Guess I'm sol
Old 04-02-2011, 08:15 AM
  #30
Blonda's Avatar
Issue seems to be most common with Rubicons with lifts running 5:13 gears... need to be very careful with alignment and vibrations as it just spins so fast. Lost ours at around 22K miles. We take our DS out now for long road trips.
Quick Reply: Another transfer case explosion/fire
