Alternative Engine Swaps
Old 10-21-2011, 12:57 PM
  #31
EzK
EzK's Avatar
I'm all for the Ford Eco boost. Smaller, lighter, more efficient and still tons of power.
Old 10-21-2011, 01:48 PM
  #32
boboborino's Avatar
I was thinking of this too(alternative motor for the JK)
Subscribed
Old 11-04-2011, 01:13 PM
  #33
B 1000's Avatar
That would be nice, but I would hate to open my Jeep hood and read "FORD" haha.
Old 11-05-2011, 03:22 AM
  #34
Mark's Avatar
Originally Posted by JdTms11
Also allot of states require the engine you swap in to be from the same make/ manufacturer and of the same model year, if not you won’t be able to register it and drive it on the road.
Its state to state. Here in MO the engine just has to be newer than the original car.
Old 11-08-2011, 02:23 AM
  #35
JKlad's Avatar
On the earlier mention of putting in a Pentastar: If I blew my 3.8L & needed a replacement motor I would certainly go the Pentastar route as with my stock 2-door Sport a fire-breathing Hemi would be overkill.
The Pentastar would be virtually plug 'n play as you wouldn't need to make any drivetrain changes (diffs, dirveshafts, axles, transmissions, transfer cases) that Hemi installs require. Not sure if the engine mounts and bellhousings are the same as the 3.8L, but still a comparatively easy install I'd say. Only problem would be to source a Pentastar as they haven't been around for that long.
Old 11-08-2011, 06:15 AM
  #36
B 1000's Avatar
Rumor mill says that the Pentastar will be direct injection soon. Curious to see what that does for added hp and mpg. But being that the P-star in general probably would br the easiest swap out there, not a bad thing to keep in mind.
Old 11-17-2011, 06:05 PM
  #37
Uticon's Avatar
My previous adventure vehicle as a 2001 Doadge Dakota Quad Cab.
It had a 4.7L V-8.
Tons of power and easy to work on and have some aftermarket support.
As soon as i got the Jeep i thought that would be the next engine for my JKUR.
As mentioned the wiring and programming would be the tuff part.
Old 11-17-2011, 06:15 PM
  #38
peanut's Avatar
X2If it were cheaper I'd honestly go the ecoboost route, its hard to beat its torque to RPM ratio not to mention the HP. But other than that, I'd go a diesel option.
Old 11-19-2011, 06:48 PM
  #39
RoughneckJeepin's Avatar
I'm really hoping to drop a ls motor in mine I'm planning to do custom aluminum dash so I should have more leeway for electronic what nots
Old 11-20-2011, 10:06 AM
  #40
StuFarmer's Avatar
Do the stock Dana 44 Diff's stand up to the task of a Hemi Swap..?
Quick Reply: Alternative Engine Swaps
