adding to my on-board air
I decided to add onto my on-board air compressor. I still have to wire up the air-switch to a relay. It will engage the air compressor under 85psi and shut it off at 106psi.
Word of caution, if you have the oil filter adapter to run an oil pressure gauge its a tight fit. Hopefully I will be able to remove the filter at my next oil change.
Finished the wiring and tested functionality. Its working great.
http://www.youtube.com/watch?v=CT9YwwgjGHI
