Added 10th Anniv. Rear bumper and AEV tire carrier
Upon verification, it looks more like 1inch lower.
Yes... you need to remove the bumper to install the tire carrier mount. Not that big of a deal... i think 8 bolts total. Then re-install the bumper once the frame Mount is installed for the tire carrier. Last step is to install the actual swing arm through the pre-drilled hole the 10a bumper.
The hitch shares the 4 bolts used by the bumper... so when you unbolt those 4 the hitch may drop out...so watch your head!
I'm slightly disappointed that they wouldn't have designed (or redesigned) the carrier so that the tire sits in the groove for the bumper. It's a great looking bumper, no doubt.
the carrier is designed to better distribute the added weight of larger tires and the larger tire you put on it (I have 37's) the more centered the tire will appear. It's designed like that intentionally
I realise that if it was centered and lower, a 37 inch tire would block the rear door handle and hardly clear the bumper, but they shohld have 2 versions, one for 33-35 inch tire, and one for 37 -40????
Even smarter, would be to have the thing designed to be centered, and have an adjustable mounting plate that could be moved sideways and up and down to accomodate different size tires and equipment.
Envoyé depuis mon MB860 avec Tapatalk
