5.13s installed and loving them!!
#22
so, if you had to do it again... or you could do a free gear swap when you get your 37's one day.. would you still for sure stay with 5:13's and not go up to the 5:38's.
I have just bought 37x12.50 17s and will run it with a 4.5 inch mopar lift (RE) I can't decide whether to just go to a 5:38 or the 5:13s. I live on an island... speed limit doesn't exceed 45. I will take it on the mainland and highway... but pretty much only for warranty work, and oil changes. Not much highway driving planned at all.
#23
Would you really notice the gear change on a 6 speed? I would think just moving all your shft points down a gear would be the same thing. Now I agree, it would make a difference if you use or need to use 6th. I thinka gear that is that tall and this low of power would be useless but first gear was just as useless on the road before my 35s.
With my 35s I just noticed first gear is more useable, the rest I just seem to stay in the next lower gear than before and nothing else has changed. I agree, the highway I need to stay in 5th unless down hill or very flat. Up hill I will stay in 5th or even 4th.
All changing my gears would do is move all my gearing back down and now I would need 6th again but would not feel any different than 5th does now at highway speeds.
Thoughts.?
Jeff
Thoughts.?
Jeff
#24
Thoughts.?
Jeff
Thoughts.?
Jeff
#25
#26
#27
#28
sounds like 5:13's wil be just fine with 37's... I agree with this thread that first gear with stock 32's is almost useless... so if 4lo.com says that 5:13's with 37's will be an improvement over stock... then coooooool!!!!!
![Thumb](https://www.jk-forum.com/forums/images/smilies/thumb.gif)
#30
All the info you need for your tranny and transfer case etc.. can be found here:
offroaders.com/tech/jeep/Jeep-Wrangler-JK-SPECS.htm
As you will see, there is a definite difference in the transmissions and transfer cases.
