5.13s installed and loving them!!
Old 04-06-2009, 07:36 PM
mkjeep's Avatar
Originally Posted by S10x1000
SHOW and tell
This is my rig
Uhh, kinda looks the same after installing the gears. HAHAha
Old 04-06-2009, 07:38 PM
edwin907's Avatar
No, you're wrong, it looks meaner, like it's got attitude!
Old 04-06-2009, 09:09 PM
mkjeep's Avatar
Had attitude, in the shop now for a transfer case prob.
Old 04-07-2009, 12:42 AM
jkJason's Avatar
Originally Posted by azeeb
What kind of RPM's are you getting on the highway? They have to be up there with 5.13's and a six speed.
x2....im curious about the drivability on the interstate. Thanks.
Old 04-07-2009, 06:31 AM
jkkat's Avatar
Its got to be close with mine, 72 MPH @ 3000 RPM
Old 04-07-2009, 05:05 PM
Strong Bad's Avatar
Originally Posted by Inglestadt
What made you go with the 5.13 vs. 4.88. I was pulling the trigger this weekend on gear until I saw your post. I use the jeep as DD and do hit some highways from time to time, but then hit fire roads and logging road on weekends. no crawling.
I went with the 5.13s because I am definitely considering going to 37s after the 35s wear out. Went to 4lo.com and did the calculations and determined that with a 6 speed and 37s I would still better than stock tires and 4.10s. After driving it with 35s I have no doubt that there will be plenty of power/torque to turn 37s.
Based on what I found out, if you have a 6 speed and stay with 35s or less 4.88s will be plenty. Hope that helps.
Old 04-07-2009, 05:07 PM
Strong Bad's Avatar
Originally Posted by stangjeeper
do you think if you go with 37's you will regre not getting 5.38's?
Definitely not with the 6 speed. 5.13s will be more than enough.
Old 04-07-2009, 05:08 PM
Strong Bad's Avatar
Originally Posted by Coolcostie
Whats you MPG now?
Haven't checked it out yet, still in the break-in period.
Old 04-07-2009, 05:10 PM
Strong Bad's Avatar
65 mph = 2800 rpms. I haven't pushed it beyond that yet. Set the cruise control and hit several inclines with NO problem.
Old 04-07-2009, 05:12 PM
lc619fr's Avatar
Man I hope I didn't make a mistake I just went to 488s but I also plan on keeping 35's I love it so far.
Quick Reply: 5.13s installed and loving them!!
