4BT cummings in a JK
#32
Originally Posted by guybergeron
where do we find a 4bt anyway? what kind of truck?
They come with the full truck or u can pick up just an engine at a place like dieselenginetrader dot com. I've seen them there.
Most reliable engine on the market.
Just stay away from the 4bta.
#33
#34
The Liberty Diesel would be a good conversion into the JK as the ecm would be a direct plug in and everything would still work.
#35
Originally Posted by Marauderer
The Liberty had the VM Motori 2.8L 4 cyl mated to the 545 automatic. basically a great setup that had 400 lb feet of torque. Naturally the US emissions messed with the motor but the two we had were great little jeeps but they were only for regular sized people and got to be a pain. They realy were like the old CJ5 with lots of bling.
#36
This subject continues to be kicked around. You can buy a complete CRD Liberty for under $5K if you look hard enough. That would give you everything you would need to make the conversion.
#38
so i HVAE FINALLY MADE A DESICION WEATHER OR NOT TO SUPERCHARGE MY JEEP OR SWAP FOR A DIESEL AND THE WINNER IS DIESEL!!!! THE REASONS BEING THAT DIESEL RUNS MORE EFFICIENTLY THAN THE GAS ENGINE AND THE MAIN REASON IS FOR MPG
I DRIVE ALOT I HAD MY JEEP JK SINCE AUGUST 2011 AND IT HAD 11K ON IT IT WAS USED AND NOW IT HAS....29,000 MILES ON IT!!!!!!!!!! NOW TO FIND SOME SHOP PROVIDING THAT I HAVE A 4BT MOTOR WOULD BE ABLE TO PROVIDE THE SWAP!!!!
