4 link
im gunna be doing a 4 link front and rear and i wanna see everyone elses setup that has done it already. and how would i double triangulate the rear with the way the gas tank sits
You would have to move the gas tank. You could put it in the rear where stock tj's gas tanks are.
OP - not sure if this would help much or if anyone has done it or if it would even work. But you might look at a 2dr tank. It must be a bit shorter than the unlimited tank. if you could swap it, that might give you enough room to put in a 4 link.
![Don't Know](https://www.jk-forum.com/forums/images/smilies/z0tdntknw.gif)
Just checked it out on their website, that thing looks nice. Unfortunately for me it looks like it will not work with the evo-lever set up.
OP - not sure if this would help much or if anyone has done it or if it would even work. But you might look at a 2dr tank. It must be a bit shorter than the unlimited tank. if you could swap it, that might give you enough room to put in a 4 link.![Don't Know](https://www.jk-forum.com/forums/images/smilies/z0tdntknw.gif)
