4" Lift w/ Stock Wheels and Tires
here is 5" with 33's so its about the same lift to tire ratio.
http://i585.photobucket.com/albums/s...g?t=1244412429
That doesn't look too bad. I just ordered my RC 4" Lift, and while I plan on going to 35" tires on 16" or 17" Cragar Soft 8s later, I'll be keeping the stock 18" with the Bridgestone Duelers for a while [which, if I'm not mistaken is close to a 33"].
i might be wrong but i do believe with stock wheels you will need wheel spacers for your tires to fit in the rear. i think the sway bar links in the rear may rub. may want to check into that.
I thought I'd need wheel spacers if I went to 35s on stock wheels . You think I'd still need spacers with stock wheels and tires with the 4" lift?
