4" Full Traction Long Arm with CRC Link
Some pics of the rear flex!
The link arms mount to the frameside trackbar mount, and a new mount bolted to the drivers side frame rail forward of the axle
install time
i did the whole lift and CRC together so i cant say how long exactly. the hardest part is drilling through the framerail for the new tower on the driver side. take your time and be patient with it! call Chris if you have any problems, hes a life saver!!
Thanks again
I bought a drill bit set and started out real small for the pilot holes and stepped up to the needed diameter. Make sure you get metal bits and a step bit is nice for the last few sizes. And I can't stress take your time measuring for the holes!!
I'm waiting on some tie rod ends so i can install my RK tie rod. I got a drop pitman arm right now and I installed the EVO sector shaft brace. And I'm thinking JKS SS relocate kit later on.
