39.5" Iroks Bad Idea on Rear D44
I know. I know. I was warned...but they looked so good. It took a 45 minute trip to the local rock spot and a heavy foot to grenade the rear trak-loc, fractured the 4.88gears, twisted splines, and cracked the axle housing. Yes, the housing for the D44 fractured on the underside near the diff cover. Oil was leaking from the fracture.
I found someone looking for the 39's and willing to trade his 37's for them. So I am replacing the rear axle with a used housing, new superior 4.88 gears, a 35 spline ARB with Superior Evolution shafts. I will be spinning the 37" Nitto Mud Grapplers. I hope this combination holds up better.
Front axle is doing okay... I was on the gas trying to get up an approx. 4' shelf... When gravity fought back the Jeep bounceed back about 2 feet... This initially did not break the rearend. It was not until I tried to go up another at another angle that their was a loud pop sound.
Wow. I would guess the bouncing weekend your rear 44 significantly, probably bending your axle, then on the next try it busted. As soon as you feel thy bounce just stop, lol.
I did the same thing to mine a year ago with 37" toyos so I dont think it was the tires.
Plus I had a heavier setup than you had with Superior 5.13 gears and Superior Chromolly Axle Shafts.
