35s on factory lift
35s on factory lift
I was wondering what all will be required, inorder to put on some 35s? I know so far, I will need to change the gearing. What gear is recommened and what lift do I need if any? Thanks.
Auto or manual? (Gearing)
Rubicon or X /Sahara (Dana 44 or 30 up front)
You will need to cut or ditch the airdam , cut/fold pinch seam turn in the steering stops 1 turn each and fender flares / fenders (Your choice) and a set of spacers (Spidertrax). Truthfully at LEAST a set of "C" Gussets to help out the front axle strength either models
This can be done no lift or a minimal 2".
35's will fit sstock with flat flares, but a min lift of 2.5" is recommended. If you have 3.73 and a manual people say its not that bad, but good to some people mite be bad to you. And spacers will be required on stock rims, after market rims with 4.75 bs will not need spacers.
Read the FAQs on the forum. These questions are answered in detail.
https://www.jk-forum.com/forums/show...l=1#post211272
