33X12.5X15 with 1.75" Front Spacers
Old 04-03-2007, 12:28 PM
JeepSWAG
Sponsoring Manufacturer
Woods's Avatar
Default 33X12.5X15 with 1.75" Front Spacers
Well I'm basically finished. I had a lot of forward rake, so I only did a lift in the front. Just now sits level. Anybody else surprised by this?
The rear wheels rub a bit at full flex.
Old 04-03-2007, 01:05 PM
Locke's Avatar
do you know what the back spacing is on your rims
thx looks very nice
Old 04-03-2007, 02:14 PM
JeepSWAG
Woods's Avatar
BS is 3.25"
Old 04-03-2007, 06:53 PM
JeepSWAG
Woods's Avatar
Originally Posted by eisenjj
Did you happen to measure things up prior to doing the lift? If so, then what was the difference from the front to the rear?
I have an X but the rake isn't that bad...only a difference of .75", so I will be doing only a .75" spacer.
BTW, Looks great!!!
Didn't measure it. What would you measure? I think the only really accurate way to measure differences between JK's is from the frame to the axle. I haven't looked for good spots. Othewise tire size, rock rails etc. would throw any measurements off.
Quick Reply: 33X12.5X15 with 1.75" Front Spacers
