33s with 2.5 lift looks
It also depends on the tire itself because some run bigger/wider than others within a given size. A larger 33 like mtr/k's looks decent on a 2 door, about the same as a 35" km2 on the same ride.
On 4 doors a 33 doesn't quite fit, imo. For 4 doors larger tires like 35's, or even 37's look right.
i put 33's on my 2011 with a teraflex 2.5 and personally i don't like it. The 35's look so much better and seem to look more like a jk should. If i could have gotten rid of my 33's i would have gone with the 35's
265/75/16's with 2.5 TF coil lift
Waiting for these to wear out. I'm still on the fence about 35's or 33's next...
I think the flares you run with the tires is an important factor.
I have the 33's already - I put spacers on so the rubbing would stop. Would you guys suggest the 2.5" terraflex spacer lift? If not, could you guys give me input in a not so expensive 2.5" lift? I won't be doing too much off roading, mostly just mudd. I did not get 35's because right now I cannot afford to re-gear, and I knew I'd hate the sluggish ride.
