2dr wraparound on 2012
Originally Posted by bobbyspaghetti
Contrary to the title of this post I would bet this would also work on a four door.
Yes i had to modify it. I added a zipper to the bottom edge and the front edge of the deck cover to seem them together added some material to the top of the windjammer along with some straps with clips to pull it up tight . And i also put velcro flaps where the seat belts go through.
Some close up pictures. The only spot water comes in is where the seat belt goes through but im going to fix that soon going to put a flap over it
zipper
When you sew the zipper and material on, are you able to use a "standard" sewing machine to do that? Also, while I am at it, can you use a standard sewing machine to work with marine grade vinyl?
