285 vs 265 duratracs
Old 08-08-2013, 06:46 PM
Halas's Avatar
I have 285 bfg km2's with 4.5 back spacing and a 3/4" puck in the front spring.
Everything is fine until you off road, I went thought a rut that stuffed the tire right up into the fender. No damage but that was the novice trail.
Old 08-08-2013, 07:27 PM
dkowalski727's Avatar
Had 285’s on stock rims and only had rubbing at FULL turn... Totally not an issue
Old 08-09-2013, 01:16 AM
JK Inspired's Avatar
285/75/17 with stock rims, NO wheel spacers, about 2 inch total suspension lift- perfect
Old 08-24-2013, 05:06 PM
Halas's Avatar
Proof of the stuffing - 285/70/17 with a 3/4" puck in front.
This is not flexed much at all and the rear rubs l and I was going very slow over a slight ditch at a local park.
I need more lift.
ID:	491339   Click image for larger version
ID:	491340   Click image for larger version
ID:	491341   Click image for larger version
ID:	491343   Click image for larger version
Old 08-24-2013, 07:46 PM
Green08jku's Avatar
Thanks guys. Looks like I'm gonna try the 285's and then the leveling kit later. I don't do much off roading so I will deal with the rubbing for a little bit.
KCCO
Quick Reply: 285 vs 265 duratracs
