285/70/17 BFG AT's
I'm putting on the TF leveling kit this weekend and was looking at this or the Duratrac in the same size or do you think I could fit the 315/70/17? I have pintler rims as well...The BF At's are 32.7 were the 315's are 34.4.
Very nice. That is the tire and probably the size I am probably going to put on mine. That or the duratracs...but need to see/'hear more about how long they are lasting.
He put spacers to accommodate for the front bumper, but I'm sure you could fit 285/70/17 tires (33's) without a lift on your stock JK. If you keep your stock wheels you may or may not need 1.5" wheel spacers depending on the width you decide on.
The tires measure 32.1x10.8 mounted on the 17x7.5 stock wheels. From what I've read else where on this forum almost all tires fall between a 1/2" to an inch short over what is specified on there web page. Basically the new tires gained me an inch in height and width.
i have run these same size tire's on my jeep for years...with and without spacers..i like the way the tire's look with the spacers though...also with spacers they do not rub at full turn and at full flex....now that i have a lift on the jeep the tire's look even better...i do more sand ,and loose dirt wheeling...so the at's perform real good for me..plus the jeep is my daily driver and they last a long time on the pavement...my next set will be bfg at's again but either 33's or 35's...
