2012 Sport S JKU - Stage One Completed
#22
Don't need to. The angle on the rear is very straight, and the front driveshaft isn't angled out at all. Maybe I'm crazy but it almost looks like Jeep moved things back a bit on the 2012 and as a result the stock driveshafts aren't all that angled even with a 4.5" lift.
When I called High Country 4X4 here in Denver (they are the best, bar none) for pricing on driveshafts, they told me flat out to run with it unless it gives me trouble, so I'm going to. On my 2dr Rubicon that I traded in, same height lift, I had to replace both. And from day one, the angle on the boot was really bad and I got spinoff within a month. The rear obviously because of the shorter wheeelbase, but the front measurements should be the same between the JK and the JKU....beats me, but the angles look great and so I'm not forking out the $1200 for driveshafts unless I have to.
#23
The lift is amazing.....the high steer kit with bilstein dampener is really, really nice. The steering feels heavy but not in a bad way, just solid, no wiggle, no wander and tracks straight as an arrow. Digging the Elkas too.
The handling kills stock. AEV lift is predictable, stable and confident feeling at the wheel.
#25
FYI, you will need the exhaust spacer (teraflex has one) or the AFE crossover. Not sure who else has fixes for the crossover location issue but a good exhaust shop could do it as well. If you go under your jeep and look at where the exhaust crossover comes in front of the frame crossmember you can see where the front drive shaft will contact it at full droop. It is barely touching at full droop on my 2.5 so I would guess your 4.5 will be at an even more extreme angle. Take a look at the video done by Teraflex on the 2012 and their exhaust spacers.
I have the teraflex spacers in now but have an AFE on order. Once it comes in I intend to wrap and spray it prior to installation to prevent any heat issues.
#26
Thanks!
#28
You definitely need to get with me on the gears and gussets. I've got a guy that did my 2009 Rubicon and will be doing this one as well. Josh will regear with Yukon gears, out the door for $825. Yeah, you read that right. He gets the gears for absolutely stupid cheap. If you bring him the sleeve/gusset kit he'll install it while doing the gears for an additional $300.
#29
#30
