2012 JK w/Bushwacker Flat Fenders
My JK after installing Bushwacker Flat Fenders, with the help from a couple of friends.
Attachment 305149Attachment 305150
I was able to do were the front fenders. Rear fenders will be put on this coming weekend.
Yeah, instruction and pics could be better. A video of the complete installation would be great. They could just post it for people to look at.
The install, with 3 of us working on it took about 5 hours.
Brown Santa just delivered these tome the other day. Been to busy to even look at installing them, and by the sounds of things...setting a wknd aside might be in order...Prior to installation did you review WOL's write-up here on the forum? I'm hoping it will make the install go smoother. Looks Great by the way!
Yes, I used the write up here. I brought it up on my lap top and used it almost every step of the way. If you take yoour time, and check your messurements several times before cutting you will be fine. Remember to always cut on the long side, as you can alway trim more off if needed but you can't add material back. It's not as bad as it sounds, just take your time.
Having another person there to confirm your markings before cutting helps, at least then you have someone else to blame.
just a fyi
