2008 rubicon build
Old 10-04-2011, 06:19 PM
arasco85's Avatar
Damn dude!
Old 10-04-2011, 06:27 PM
inspect-a-home's Avatar
What model ford was that, Is it from your truck?
Do u know how to weld EVO gussets?
Old 10-04-2011, 06:34 PM
scooby snacks's Avatar
Don't think they'll need gussets or sleeves... those suckers are massive.
Any thoughts on the brakes working with your existing brake booster and ABS system or are you removing all that and replacing it too?
Subscribed.
Old 10-05-2011, 02:28 AM
Jeff76's Avatar
Late model f 250 ford. Not sure exactly what year.
Yes I can weld evo gussets. Do ball joints need to be removed?
Old 10-05-2011, 02:30 AM
Jeff76's Avatar
Subscribed.
I'll cross that bridge when I get there. I'm not worried about abs working.
Old 10-05-2011, 12:00 PM
jeep2007's Avatar
Great read and it will be fun to watch. Best of luck to you!
Old 10-06-2011, 04:12 PM
Jeff76's Avatar
Got the rear axle ready for truss and 4 link tabs. Also pulled off the parking brake components.
Started cutting the huge ford brackets off the Dana 60 front.
ID:	220050   Click image for larger version
Old 10-09-2011, 01:02 PM
Jeff76's Avatar
Finally got all the ford brackets cut off the front axle. The driver side was part of the casting so it was a pita to cut and grind off.
Waiting for my truss and brackets from blue torch fab. They should be here this week.
Old 10-09-2011, 01:54 PM
thanks to Jeff my EVO upper and lower gussets are welded in, he did a awesome job! Hey man..Ill let ya know if I have anything else to weld. Now, time to go wheeling and test these out!
Old 10-09-2011, 03:06 PM
Jeff76's Avatar
The axle tube to the left of the pumpkin was a huge bracket/bumpstop pad that was cast in to the housing. I got it all off so now I have somewhere to mount 4 link tabs and coilover tabs.
Quick Reply: 2008 rubicon build
