2008 rubicon build
Old 01-22-2012, 01:51 PM
  #141
Jeff76's Avatar
Well I just decided to fab some hoops out of tubing for the upper c/o mounts. So basically everything in the fender wells will be deleted or relocated.
Passenger side airbox is gone, fuse panel will be relocated, may move the battery to the rear.
Driver side ESP box will be deleted, ECM moved, and ws wiper reservoir will be moved.
Also got the power steering box off. Psc full hydro will be going on in the next few weeks.
ID:	268295   Click image for larger version
Old 01-22-2012, 05:58 PM
  #142
CALIJK's Avatar
Originally Posted by Jeff76
Well I just decided to fab some hoops out of tubing for the upper c/o mounts. So basically everything in the fender wells will be deleted or relocated. Passenger side airbox is gone, fuse panel will be relocated, may move the battery to the rear. Driver side ESP box will be deleted, ECM moved, and ws wiper reservoir will be moved. Also got the power steering box off. Psc full hydro will be going on in the next few weeks.
I say just really go for it and cut through the hood like the TJ guys do!
Old 01-23-2012, 06:51 AM
  #143
Jeff76's Avatar
I don't need hoops that tall. If I sat it that low my 42's would be well in to the sheetmetal before I reached full uptravel.
They will end up 13-14"above the framerail.
Old 01-26-2012, 02:30 PM
  #144
Jeff76's Avatar
Psc full hydro kit ordered today. Should have it sometime next week.
Old 01-26-2012, 03:22 PM
  #145
CALIJK's Avatar
Nice. Can you tell me why you decided to go full-hydro instead of hydro-assist?
Old 01-27-2012, 03:01 AM
  #146
Jeff76's Avatar
Stronger and less shit to break. Also allows the front wheelbase to be streched forward as much as I want.
Old 01-31-2012, 05:21 PM
  #147
Jeff76's Avatar
Got the front coilover hoops cut to size. .120x1.75 Dom. Driver side is finished minus some gussets that will go from hoop to frame.
Should have the pass side done this w end. Also making a peice of tubing that runs over engine and connects the hoops together. This peice will be removable.
ID:	272826   Click image for larger version
Old 02-01-2012, 04:08 AM
  #148
Garald_JK's Avatar
You do good work Jeff76. And your build has inspired me.
Can't wait to see the finished product. Wish I was in your area so I could come check it out in person.
Cheers
Old 02-04-2012, 04:52 PM
  #149
Jeff76's Avatar
Started working on my Psc full hydro steering. Got the orbital valve and ram mounted.
Have to make some highsteer arms out of 3/4" plate, add a cooler, install new pump, and run all lines. Doubt I'll get anything done Tom. It's superbowl, BBQ, beer time.
ID:	274021   Click image for larger version
Old 04-07-2012, 07:57 AM
  #150
Mr. Smiley's Avatar
Any updates.?
Quick Reply: 2008 rubicon build
